Date/Time: Mon, 23 Dec 2024 17:45:07 +0000
Problem with Simulation On Spiders 60 Days Or Longer
View Count: 694
[2015-10-13 01:42:01]
CMG - Posts: 179
The spreadsheet formula closes out positions at 16:00. If I do the simulation for the last 30 days the formula works fine, but if it is a 60 day simulation or longer, the positions are not closing out at 16:00.
Any thoughts?
[Files are saved in ticks]
[2015-10-13 01:59:59]
You really need to debug this. We have no idea why you would have a problem with this. You just need to run a slow speed replay and watch what is happening with the data and formulas and see why there is a problem.
[2015-10-13 18:18:15]
CMG - Posts: 179
For future reference cell J28 and J29 had the same 16:00, I changed J28 to 16:15 so that solved the problem. Also on chart setting, I extended the chart time to 17:00. If those 3 setting, some positions may be left open.
