Date/Time: Mon, 23 Dec 2024 17:08:02 +0000
Customize keyboard shortcuts for multiple configurations of same drawing tool
View Count: 1091
[2015-10-12 22:51:28] |
User529296 - Posts: 27 |
Hello, Right now, I only see assigning only one keyboard shortcut to a drawing tool in "customize keyboard shortcuts" under "global settings". Is there a way to assign different keyboard shortcuts to multiple configurations of same drawing tool, for example, TC1 and TC2 of Vertical Line? I already saved these configurations. Thank you! |
[2015-10-15 09:16:02] |
We have prepared documentation for this here: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#CreatingToolBarButtons Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
