Date/Time: Mon, 23 Dec 2024 15:54:30 +0000
slow data
View Count: 694
[2015-10-12 22:50:43] |
User716402 - Posts: 28 |
is there a problem with slow data on your end or is it mine
[2015-10-12 23:45:27] |
We see you are using the Rithmic trading platform service. Therefore, the data feed comes from the Rithmic system. Not from Sierra Chart. Refer to help topic 4 here: Http://www.sierrachart.com/index.php?page=doc/helpdetails4.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
