Date/Time: Mon, 23 Dec 2024 15:45:56 +0000
incomplete historical data display in destination instance
View Count: 772
[2015-10-12 20:36:19]
sierra28 - Posts: 120
hello,
i have 2 instances of sierra:
source for data futur contract
destination for trading with Lmax.
in the capture you can see that datas are incomplete with lot of intraday gaps whereas if i display this same chart in the source instance, datas are display correctly.
i suppose there is a parameter in destination instance responsible of this problem but i can't find it.
any idea ?
thanks
imagehistorical data from source display in destination instance.JPG / V - Attached On 2015-10-12 20:34:54 UTC - Size: 268.58 KB - 274 views
[2015-10-13 04:02:21]
The problem is you are using futures contract data from a remote instance and in that case the Continuous Futures Contract feature does not work across instances of Sierra Chart like this.
So the data towards the left of the chart is during an inactive time for that futures contract because the chart only contains a single contract.
[2015-10-13 07:02:32]
So no any solution ?.
i will have to open 2 chartbooks: one for intraday and trading charts and the other for historical data...
[2015-10-13 07:26:37]
You can only look at continuous Futures Contract charts in the instance of Sierra Chart where the data originates from.
