Date/Time: Mon, 16 Sep 2024 19:46:48 +0000
live trading using FXCM Forex data and Sierra Chart connected to Interactive Brokers?
View Count: 892
[2015-10-12 15:30:15] |
User68117 - Posts: 65 |
Hello, I want to ask. I am a broker Interactive Brokers. Can I sort of live trading using FXCM Forex data and Sierra Chart connected to Interactive Brokers? |
[2015-10-12 21:19:08] |
What is supported is the ability to use the Sierra Chart historical Forex data when using an Interactive Brokers Forex symbol (IDEALPRO) but the real-time updating will use the Interactive Brokers data feed. You just need to enable Global Settings >> Data/Trade Service settings >>Support Alternate Forex Historical Data. After this re-download the data in the chart with Edit >> Delete All Data and Download. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-02-04 16:34:20] |
User349277 - Posts: 1 |
What is the minimal package for this functionality?
[2016-02-04 18:38:56] |
Sierra Chart service package 3 is needed for what is described in post #2. Make sure Sierra Chart is up to date: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-02-04 18:39:19
