Date/Time: Sun, 18 Oct 2026 05:41:25 +0000
Win 10 Build Custom Studies DLL issue, I think
View Count: 1756
[2015-10-12 15:21:14]
jsob - Posts: 40
I have been successfully developing/building a custom study in Win 7 for quite some time. I installed Win 10 yesterday and today I cannot recompile my study. I get the same result whether I use version 1307 or the pre-release 1308. I do not know how to interpret this. The report:
-- Starting build of Custom Studies Source files: RSD_19_June_2014.cpp. -- 11:08:50
"C:\SierraChart\CPPCompiler\bin\g++.exe" "C:\SierraChart\ACS_Source\RSD_19_June_2014.cpp" -march=i686 -mtune=i686 -O2 -shared -static -static-libgcc -static-libstdc++ -s -fno-rtti -fno-exceptions -std=gnu++11 -o "C:\SierraChart\Data\RSD_19_June_2014.dll"
In file included from C:\SierraChart\ACS_Source\sierrachart.h:15:0,
from C:\SierraChart\ACS_Source\RSD_19_June_2014.cpp:1:
C:\SierraChart\ACS_Source\RSD_19_June_2014.cpp: In function 'void scsf_LSMA_WTMA_Lines(SCStudyInterfaceRef)':
C:\SierraChart\ACS_Source\scstructures.h:48:28: error: expected unqualified-id before string constant
#define SCDLLEXPORT extern "C" __declspec(dllexport)
C:\SierraChart\ACS_Source\scstructures.h:51:20: note: in expansion of macro 'SCDLLEXPORT'
#define SCSFExport SCDLLEXPORT void SCDLLCALL // Use SCSFExport when defining a study function
C:\SierraChart\ACS_Source\RSD_19_June_2014.cpp:3145:1: note: in expansion of macro 'SCSFExport'
SCSFExport scsf_15_LSMA_plot(SCStudyInterfaceRef sc)
C:\SierraChart\ACS_Source\RSD_19_June_2014.cpp:3983:1: error: expected '}' at end of input
-- End of Build -- 11:08:50
[2015-10-12 17:33:28]
This does not look like it would be Windows 10 specific.
Not sure this will help, but reinstall the compiler again by following these instructions:
https://www.sierrachart.com/index.php?page=doc/doc_CreatingDLLs.html#ReinstallingCPPCompiler
The next step is to compile the Template.cpp file in the /ACS_Source folder and see if you get the same errors.
Date Time Of Last Edit: 2015-10-13 17:02:00
[2015-10-12 23:26:19]
jsob - Posts: 40
Followed your suggestion twice with same result:
-- Starting build of Custom Studies Source files: RSD_19_June_2014.cpp. -- 19:22:35
-- End of Build -- 19:22:35
Following is the script produced by the compilation process:
Date Time Of Last Edit: 2015-10-13 17:01:24
[2015-10-13 13:07:50]
jsob - Posts: 40
I am profoundly sorry for wasting your time. The error was all my own, a missing curly brace. As a rank amateur I was overwhelmed by the compiler references and did not trouble myself to examine the reported coding error. It was only after I installed MS Visual C++ Visual Express, that I began to look seriously for the error. I am truly sorry for wasting your time.
Thank you for an excellent product...and your patience.
[2015-10-13 17:04:19]
OK this is good, this is why we had said to compile the Template.cpp file which is located in the /ACS_Source folder.
