Date/Time: Mon, 23 Dec 2024 16:08:39 +0000
Icebergs - feature request to Time and sales
View Count: 1522
[2015-10-12 09:46:18] |
Sebastian_M - Posts: 70 |
Would it be possible to add a highlight background feature when 3 or more trades happen at the same price in succession as per image attached as I am trying to make Icebergs obvious, with an alert as well. If anyone else would like this feature, then please add your intrest. Thanks in advance. Sebastian |
Icebergs.jpg / V - Attached On 2015-10-12 09:42:34 UTC - Size: 137.48 KB - 475 views |
[2015-10-12 17:14:39] |
You could create a custom study that provides some kind of an alert visually on the chart and also provides an alert sound. The Time and Sales data is accessible using ACSIL. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members.html https://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Functions.html#scGetTimeAndSales Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-12 17:15:00
[2015-10-12 17:36:19] |
Hi Support, That would be a great idea if I could actually code it, but the reality is that I am just a beginner. This is why I am asking you. If anyone would like to try it and post the code/link library, it would be a big help to all Sierra chart users. Perhaps put a triangle up/down on the chart as well. https://www.youtube.com/watch?v=DV8BTUSZwNw Regards Sebastian |
[2015-10-12 22:18:45] |
i960 - Posts: 360 |
I suggest you look into the number bars study. What you're really looking for is volume hit at bid vs ask at a certain price and position within the chart. That's what number bars provide. They won't tell you iceberg or non-iceberg, but they can point to significant firmness at a specific price level.
