Date/Time: Mon, 23 Dec 2024 15:51:58 +0000
ACSIL: Getting the most recent order
View Count: 788
[2015-10-12 06:53:30] |
William O - Posts: 16 |
I would like to get the most recent order submitted (not necessarily filled), preferably without using looping. Am I safe to assume that sc.GetOrderByIndex() is ordered where the last element is the most recent order? If so is there a way to get the order array size similar to sc.GetOrderFillArraySize()? With the order array size i'd be able to easily grab the last element. Thank you.
[2015-10-12 17:26:55] |
It is not as simple as this because the order list can change when it is sorted when left clicking on the column headers on the Trade >> Trade Orders and Positions >> Orders tab. You really need to iterate through all of the orders and find the one with the latest s_SCTradeOrder::EntryDateTime. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
