Date/Time: Mon, 23 Dec 2024 15:59:36 +0000
Amount of internet(MB) usage of SC
View Count: 877
[2015-10-11 03:10:29] |
Lux - Posts: 14 |
Hi there! I will be staying for two months at the place where there is no other option for internet then prepaid wlan USB stick. As they charge quite a bit per 1MB of traffic,i was wondering how much MBs does SC normally use when one is just looking at live market,without downloading large historical and intraday files? Date Time Of Last Edit: 2015-10-11 03:11:24
[2015-10-11 03:15:54] |
We see you are running version 1307 of Sierra Chart. If you look at the Status Bar: https://www.sierrachart.com/index.php?page=doc/doc_StatusBar.html There is a new field called BR which indicates the bytes received in kilobytes. You can monitor this for a few days to get an idea. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-11 03:16:30
[2015-10-11 05:13:58] |
Lux - Posts: 14 |
Will do. Thanks for the swift response! |
