Date/Time: Mon, 23 Dec 2024 16:16:35 +0000
Larger graphics on my retina display
View Count: 936
[2015-10-10 19:44:45]
User957752 - Posts: 9
I recently purchased a MacBook Pro with the retina display. I am running Sierra charts v1261 within parallels 10 & Win pro v7.
While I have the charts looking fine, I'm trying to get the tool buttons and tabs to be larger. I don't see any way to do this. I have tried making the font larger and all that happens is the text gets cropped up. Is there any way to make the buttons and tabs larger?
Thanks.
imageScreen Shot 1.png / V - Attached On 2015-10-10 19:43:12 UTC - Size: 45.58 KB - 308 views
imageScreen Shot 2.png / V - Attached On 2015-10-10 19:43:22 UTC - Size: 18.66 KB - 307 views
[2015-10-10 22:20:35]
You need to update to the latest version of Sierra Chart. This is an absolute must to accomplish what you want.
You can then increase the font sizes in Global Settings >> Graphics Settings >> Fonts to do what you want.
[2015-10-12 14:05:38]
Thanks Sierra Chart Engineering. I upgraded the the latest version & the buttons & tabbies look good now.
