Date/Time: Fri, 27 Dec 2024 02:31:10 +0000
Historical error filtered (in just one machine out of 2)
View Count: 759
[2015-10-10 14:58:48] |
Guilherme - Posts: 66 |
Hi. I run Sierra Chart in 2 machines. Both run the exact the same version of the software. In one of them, I'm getting this "historical error filtered" for last friday session, in just one symbol. The other one loads the data correctly. I tried to manually delete the data base, and even reinstall Sierra from scratch, but nothing worked out. Any clue about how to fix it? []s Guilherme |
[2015-10-10 17:59:32] |
Just an update. I deleted and downloaded data from the machine that was working, and now both machines present the same error for this particular instrument. I use IQFeed, by the way. When loading the instrument in Ninja, it works ok.
[2015-10-11 02:59:40] |
You need to disable error filtering: http://www.sierrachart.com/index.php?page=doc/doc_ErrorFilter.html#DisablingErrorFiltering Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-03-04 05:34:48] |
Refer to the documentation for this here: http://www.sierrachart.com/index.php?page=doc/doc_ErrorFilter.html#DisablingErrorFiltering Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
