Date/Time: Sat, 12 Sep 2026 14:50:33 +0000
Compiling study gives error
View Count: 1590
[2015-10-09 23:42:46]
KhaosTrader - Posts: 128
I copied the "SCSFExport scsf_BollingerSqueeze(SCStudyInterfaceRef sc)" code into my own custom study file.
When I try to compile it (unmodified) I get the following error:
"None of the selected source files contains the SCDLLName line at the top of the file. Refer to ACSIL documentation.
-- End of Build -- 19:38:39"
I have the following include:
#include "sierrachart.h"
#include <math.h>
#include "scstudyfunctions.h"
What must I do to make it compile?
By the way , here is the code:
Bollinger bands squeeze.
Proportion = (kUpper - kLower) / (bbUpper - bbLower);
  SCSubgraphRef BandsRatio = sc.Subgraph[0];
  SCSubgraphRef SqueezeIndicator = sc.Subgraph[1];
  SCSubgraphRef Keltner = sc.Subgraph[2];
  SCSubgraphRef BollingerBands = sc.Subgraph[3];
  SCInputRef InputData = sc.Input[0];
  SCInputRef InternalMovAvgType = sc.Input[1];
  SCInputRef KeltnerBandsLength = sc.Input[2];
  SCInputRef KeltnerTrueRangeMALength = sc.Input[3];
  SCInputRef KeltnerBandsMultiplier = sc.Input[4];
  SCInputRef BollingerBandsLength = sc.Input[5];
  SCInputRef BollingerBandsMultiplier = sc.Input[6];
  if (sc.SetDefaults)
    sc.GraphName="Bollinger Squeeze";
    sc.StudyDescription="Bollinger Squeeze";
    sc.AutoLoop = 1;
    sc.GraphRegion = 1;
    BandsRatio.Name = "Bands Ratio";
    BandsRatio.DrawStyle = DRAWSTYLE_BAR;
    BandsRatio.PrimaryColor = RGB(0,255,0);
    BandsRatio.SecondaryColor = RGB(255,0,0);
    BandsRatio.SecondaryColorUsed = true;
    BandsRatio.DrawZeros = true;
    SqueezeIndicator.Name = "Squeeze Indicator";
    SqueezeIndicator.DrawStyle = DRAWSTYLE_POINT;
    SqueezeIndicator.LineWidth = 3;
    SqueezeIndicator.PrimaryColor = RGB(0,255,0);
    SqueezeIndicator.SecondaryColor = RGB(255,0,0);
    SqueezeIndicator.SecondaryColorUsed = true;
    SqueezeIndicator.DrawZeros = true;
    InputData.Name = "Input Data";
    InputData.SetInputDataIndex(SC_LAST);
    InternalMovAvgType.Name="Moving Average Type for Internal Calculations";
    InternalMovAvgType.SetMovAvgType(MOVAVGTYPE_SIMPLE);
    KeltnerBandsLength.Name="Keltner Bands Length";
    KeltnerBandsLength.SetInt(20);
    KeltnerBandsLength.SetIntLimits(1,MAX_STUDY_LENGTH);
    KeltnerTrueRangeMALength.Name = "Keltner True Range MovAvg Length";
    KeltnerTrueRangeMALength.SetInt(20);
    KeltnerTrueRangeMALength.SetIntLimits(1,MAX_STUDY_LENGTH);
    KeltnerBandsMultiplier.Name="Keltner Bands Multiplier";
    KeltnerBandsMultiplier.SetFloat(2.0f);
    BollingerBandsLength.Name="Bollinger Bands Length";
    BollingerBandsLength.SetInt(20);
    BollingerBandsLength.SetIntLimits(1,MAX_STUDY_LENGTH);
    BollingerBandsMultiplier.Name="Bollinger Bands Multiplier";
    BollingerBandsMultiplier.SetFloat(2.0f);
    return;
  if ((sc.CurrentIndex < KeltnerBandsLength.GetInt()) || (sc.CurrentIndex < BollingerBandsLength.GetInt()))
    return;
  // calculate Bollinger Bands
  sc.BollingerBands(sc.BaseData[InputData.GetInputDataIndex()],BollingerBands,BollingerBandsLength.GetInt(),BollingerBandsMultiplier.GetFloat(),InternalMovAvgType.GetMovAvgType());
  // calculate Keltner
  sc.Keltner( sc.BaseData,sc.BaseData[InputData.GetInputDataIndex()],Keltner,KeltnerBandsLength.GetInt(), InternalMovAvgType.GetMovAvgType(),BollingerBandsLength.GetInt(),InternalMovAvgType.GetMovAvgType(), KeltnerBandsMultiplier.GetFloat(),KeltnerBandsMultiplier.GetFloat());
  float KUp = Keltner.Arrays[0][sc.CurrentIndex];
  float KDown = Keltner.Arrays[1][sc.CurrentIndex];
  float UBB = BollingerBands.Arrays[0][sc.CurrentIndex];
  float LBB = BollingerBands.Arrays[1][sc.CurrentIndex];
  if ((UBB > KUp) && (LBB < KDown))
    SqueezeIndicator.DataColor[sc.CurrentIndex] = SqueezeIndicator.PrimaryColor;
  else
    SqueezeIndicator.DataColor[sc.CurrentIndex] = SqueezeIndicator.SecondaryColor;
  BandsRatio[sc.CurrentIndex] = (KUp-KDown)/(UBB - LBB) - 1.0f;
  if (BandsRatio[sc.CurrentIndex] >= 0)
    BandsRatio.DataColor[sc.CurrentIndex] = BandsRatio.PrimaryColor;
  else
    BandsRatio.DataColor[sc.CurrentIndex] = BandsRatio.SecondaryColor;
[2015-10-10 00:40:28]
Nevermind, I resolved this issue, the SCDLLName("Custom Study DLL") was not at the top of the file, I moved it, it now works, sorry
