Date/Time: Sun, 13 Sep 2026 12:34:52 +0000
30 second charts
View Count: 2178
| [2015-10-09 19:06:16] |
| User623839 - Posts: 108 |
Do any of your historical data feeds have 30 second charts? It doesn't work when I switch to Sierra's Historical Data. I am only able to change the chart to 0-0-30 when Im hooked up to my IB feed? I have version 3. Ideas? |
| [2015-10-09 19:31:34] |
The Sierra Chart Historical Data service provides tick by tick data. So you most certainly can create 30 second charts. Follow the instructions here: Tick by Tick Data Configuration And these instructions here: https://www.sierrachart.com/index.php?page=doc/IB.php#UsingSierraChartHistoricalData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-10-09 20:39:53] |
Works now. Sometimes it doesnt. Maybe need to refresh more often. Thanks
| [2015-10-13 15:57:05] |
The 30 second chart is not working with my EQUITIES it is only working with the futures charts. Ideas? It shows 30 second data ahead of the price action (where it has yet to plot) but when you cursor over where price has already plotted it's only 1 minute candles. |
| [2015-10-13 17:24:32] |
This does not make technical sense as long as you follow through these instructions: Follow the instructions here: Tick by Tick Data Configuration And these instructions here: https://www.sierrachart.com/index.php?page=doc/IB.php#UsingSierraChartHistoricalData Provide an image of the chart, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-10-14 00:39:59] |
Here are some chart pics to review
Date Time Of Last Edit: 2015-10-14 00:40:12
| [2015-10-14 01:44:17] |
As mentioned before when Im using the data feed through IB it displays the 30 second chart fine. When I switch to Historical Sierra data it does not give me anything under a minute.
| [2015-10-14 02:09:54] |
OK we had gotten confused because you had mentioned Interactive Brokers in the beginning so we thought the data was being downloaded when Interactive Brokers was being used. Update to the latest release of Sierra Chart, and even when the "SC Historical Data Service" is the selected Service, you will get 1 second data for US stocks/equities. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-10-15 14:13:47] |
Cool thanks!
