Date/Time: Sun, 08 Sep 2024 03:27:59 +0000
getting crosshair when using tools
View Count: 813
[2015-10-09 14:38:46] |
Shelby Cobra - Posts: 22 |
i'm now getting a crosshair drawing all kind of tool and it's kinda of annoying when to my work. Can this be turned off? I went into global settings, then into tool config and was able to turn it off. Now it turns off the crosshair all together and i can't use the crosshair tool just by itself when selected from my toolbar shortcut. can you get fix this so i don't get a crosshair when using other tools like, " trendline or drawing things on my chart? jon |
[2015-10-09 14:48:11] |
figured it out, sorry for the post. saw that there is a selection now for crosshair in the tool settings and switched to "none", encase anyone of interested.
[2015-10-09 17:32:50] |
Yes you need to change the Global Settings >> Tool Settings >> Chart Values >> Always On/Enabled When Using Other Tools to None.
