Date/Time: Mon, 23 Dec 2024 15:39:16 +0000
Help with alerts.
View Count: 697
[2015-10-09 14:02:17] |
User96815 - Posts: 2 |
Hi, I need some help setting alerts. Basically I want an sound alert every time the ask/bid vol difference study is negative and the tick price bar closes above it's open. And vice versa. Thanks in advance.
[2015-10-09 17:45:29] |
Refer to this page: https://www.sierrachart.com/index.php?page=doc/doc_AlertCondAndScan.html We do not provide alert formula programming help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-10-09 19:01:37] |
Sawtooth - Posts: 4141 |
Try this: =AND(ID1.SG4<0,C>O) where ID1 is the Ask/Bid Volume Difference Bars study. |
[2015-10-12 11:55:15] |
Thanks for that! Tomgilb
