Date/Time: Fri, 27 Dec 2024 02:26:04 +0000
I want Message Log to appear only when I want it to
View Count: 789
[2015-10-09 13:57:49] |
BataviaTrader - Posts: 63 |
Is there any possibilty to open the Message Log in the event only I want it to? Now it pops up anytime it feels like popping up, cluttering my screens while trading, which is annoying. I have de-selected the option Show-Hide Message Log, so I supposed that would do the trick, but it it does not. Please advice, thank you. |
[2015-10-09 17:21:34] |
The answer is a definite no. If the Message Log is opening there is a reason for it. So what is the reason? If you look at the Message Log, the lines with an asterisk (*) at the end cause it to open. Post those here. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-03-15 17:44:34] |
Sawtooth - Posts: 4143 |
The solution I use it to grap a corner of the log window and shrink it so it can be parked out of the way.
[2016-03-15 19:36:38] |
User51166 - Posts: 33 |
I wanted too, I don't want move every time some form which can be off
