Date/Time: Fri, 20 Nov 2026 15:48:21 +0000
STUDIES DON'T REFRESH
View Count: 2599
| [2015-10-09 13:24:43] |
| jivetrader - Posts: 410 |
2 colorbar studies (simple alerts based on Numbers Bars Calc Values) do not refresh (they keep old inaccurate values) without manually refreshing the chart. i have seen this behaviour with other similar reference/derivative studies and usually i can get around it or avoid it but this issue makes charts unreliable. please advise.
| [2015-10-09 18:29:16] |
This is the problem: AND(ID3.SG6>ID3.SG6[1],ID3.SG6>ID3.SG6[2],ID3.SG6>ID3.SG6[3],ID3.SG6>ID3.SG6[4],ID3.SG6>ID3.SG6[5])
The formula is referencing Subgraph elements which either do not exist or are changing when being referenced by prior study columns. Refer to the documentation here for the [] operator: https://www.sierrachart.com/index.php?page=doc/doc_AlertCondAndScan.html#ReferencingDataOtherLastBar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
