Date/Time: Sun, 08 Sep 2024 03:41:52 +0000
Parallel rays doesn´t correspond at different timeframes
View Count: 722
[2015-10-09 10:44:44] |
3V - Posts: 1 |
Candlesticks at the 1H and 5M chart are at different sides of same Parallel Rays (charts are linked). See attached PrintScreen. |
example.JPG / V - Attached On 2015-10-09 10:43:20 UTC - Size: 221.72 KB - 277 views |
[2015-10-09 18:32:42] |
Refer to this help topic: https://www.sierrachart.com/index.php?page=doc/helpdetails34.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
