Date/Time: Mon, 23 Dec 2024 15:34:03 +0000
numbers bars calculated values. how to display these as bars?
View Count: 855
[2015-10-09 10:14:24] |
User59157 - Posts: 5 |
hello, i have used market delta for a while in the past and i found it most useful to display the delta as a bar chart underneath the main price chart based on +/- i have looked but i cannot find a way of showing the delta visually like this. for example right now i have the numbers bars calculated values under my price chart showing the askv-bidv but i seem to be only able to display this numerically. i hope you can help much thanks Daniel |
[2015-10-09 18:36:27] |
It sounds like the study you are looking for is Bid Volume versus Ask Volume: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s127 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-09 18:36:55
