Date/Time: Sun, 08 Sep 2024 01:56:21 +0000
automated trading strategy
View Count: 817
[2015-10-09 04:59:59] |
jesyna - Posts: 2 |
We tried to configure the following automated strategy but it did not work: I open position of three contracts, initial protective stop loss set at 8 ticks for all three contracts. 2 contracts have profit target of 4 ticks. When this target is met, I want stop loss for third contract moved to break even, and the third contract becomes a runner with no set profit target in the configuration. Can you tell me how to configure? Thanks ! JE |
![]() Attachment Deleted. |
[2015-10-09 20:29:22] |
For the Stop 2 order you need to set the Move to Breakeven settings as explained here: https://www.sierrachart.com/index.php?page=doc/doc_AttachedOrders.html#MoveBreakevenForStop So you need to select Stop 2 on the list of Attached orders on the Targets tab and set the settings as required. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-10-15 02:22:29] |
jesyna - Posts: 2 |
Is this CORRECT??? Please see attached PNG
[2015-10-16 05:50:30] |
Refer to the attached image for the settings. Confirm this works for you. There should be no trouble with it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-16 05:51:16
