Date/Time: Thu, 24 Sep 2026 19:15:04 +0000
Offline Help
View Count: 1789
| [2015-10-09 01:42:12] |
| User150371 - Posts: 70 |
Hello, is Documentation-Table of contents etc.- available offline, or only through the sierrachart website ?
| [2015-10-09 03:56:54] |
Only through the website.
| [2016-03-12 18:10:10] |
| User13668 - Posts: 296 |
I was interested to know why SC does not make the documentation available for offline access. I spend a lot of time in trains and planes and could make better use of the time by swatting up on some aspects of SC that I have not paid enough attention to. If the reason SC does not make this available is because of a concern that users will raise support issues by referencing out of date documentation that they previously downloaded, why could the download not include a watermark or footer that says 'this documentation is only valid as at {date downloaded]'? There seems to be a history of users asking for offline access, see: Offline documentation http://www.sierrachart.com/supportboard/showthread.php?t=28252 as two examples I found with a simple Support Board search. Cheers |
| [2016-03-14 09:51:02] |
We are seeing if it there is a way we could possibly do this. It will take some time though. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-07-20 11:52:05] |
Is there any progress on this? I really miss this feature at this time of the year when one can be travelling a lot for holidays or on holiday with inadequate internet coverage. Thanks |
| [2016-07-20 16:49:34] |
We have not had any time to work on this. So there has been no progress. We will have to look up the task related to this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-07-20 17:07:20
| [2016-10-21 18:46:22] |
Thanks for doing this: https://www.sierrachart.com/index.php?page=doc/Contents.php https://www.sierrachart.com/downloads/SierraChartDocumentation.zip I just noticed it now, so I am not sure when you added it - don't recall seeing it mentioned in the Change Log, so thought I would make this post in case others are interested. How often is the off-line version updated? I ask because I just had a quick try of it and noticed the offline page (CQG Trading Platform Service) I was looking at was last updated 17 September, yet the Live online version has an updated date of 5 October. |
| [2016-10-21 19:49:38] |
The offline documentation is updated weekly. The last update was 1 week ago. A new copy has been just uploaded.
Sierra Chart Support Date Time Of Last Edit: 2020-02-17 15:35:52
| [2020-02-15 15:53:58] |
| User267255 - Posts: 1 |
hi i downloaded the offline documentation.... it seems graphic files are not part of it, i have to connect online to see the images is this the case? there is an 'image' folder but it just contains 1 file, 'Logo' thanks for any explanation so i can view the help docs when traveling and not connected Date Time Of Last Edit: 2020-02-15 15:54:57
| [2020-02-17 17:45:19] |
This has been resolved. Recently the defaults of the program that is used to make the offline copy has changed. Sierra Chart Support |
