Date/Time: Mon, 23 Dec 2024 16:38:41 +0000
Crosshair Problem
View Count: 826
[2015-10-09 01:07:14] |
Trader Ra - Posts: 87 |
Is there a way to choose which line to display on the crosshair? ie. can i hide the horizontal bar and only have the vertical bar showing. I find the horizontal bar distracting and unnecessary esp. when you have lines drawn on the charts.
[2015-10-09 03:57:09] |
No, but this is easily added.
[2015-10-09 06:53:55] |
Great. If it's easy to implement, can we expect to see this option added sometime soon or is this going on the back burner for now. Thanks.
[2015-10-09 07:25:47] |
We can do it, but probably will take a couple of months. We have put this down on the near-term list.
