Date/Time: Mon, 23 Dec 2024 16:04:58 +0000
study for 20 period hi/low---min/max?
View Count: 942
[2015-10-08 19:20:02] |
User170575 - Posts: 221 |
Hi, Is there a study that will indicate a 20 period hi or low? Many thanks, Cy |
[2015-10-09 04:18:03] |
Have a look at the High/Low for Time Period study: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s246 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
