Date/Time: Mon, 23 Dec 2024 16:22:29 +0000
Compact Tool Values Window
View Count: 1083
[2015-10-08 14:17:54] |
User35326 - Posts: 57 |
SC: Why did I lose my compact tool value window on some charts that I have up? When I click on: window -> show compact tool values window, the software shows that I have that line item checked. However, I can't find the compact tool values window anywhere? Usually, If I click on a chart then the compact tool values window will appear and if I click again, it will go away. This is not happening on every chart I have on my chartbook, just two of them are having this problem? How do I find the compact tool values window? Date Time Of Last Edit: 2015-10-08 14:18:56
[2015-10-08 17:08:44] |
You need to select Chart >> Reset Child Windows. You may also want to uncheck this option: Global Settings >> Tool Settings >> Save CTV Window Position for Each Chart. This is also documented here: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ViewingToolandChartData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
