Date/Time: Mon, 23 Dec 2024 15:37:28 +0000
Display
View Count: 762
[2015-10-08 09:43:26] |
User998091 - Posts: 2 |
Hi, sometimes when I have moving averages on a chart it shows the full length of the ma and the candlesticks become very compressed. Is there any way that I can set the display so that the candlesticks automatically get priority i.e. go from top to bottom of screen? Thanks
[2015-10-08 10:25:26] |
Refer to the documentation for this here: https://www.sierrachart.com/index.php?page=doc/doc_Scaling.html#BasingScalePriceBars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
