Date/Time: Mon, 23 Dec 2024 15:41:09 +0000
Eurex symbol
View Count: 928
[2015-10-08 06:53:59] |
Forward - Posts: 65 |
Hello at All, i added EUREX exchange but i don't see any Eurex symbols in the " Find Symbol" list. Must i importe them ? Which is your Euro Stoxx 50 symbol ? |
[2015-10-08 09:21:53] |
The symbols depend upon what Service in Sierra Chart you are using. If you have set Global Settings >> Data/Trade Service Settings >> Service to "SC Exchange Data", the symbol will be: FXZ15. The symbols are in File >> Find Symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-10-08 11:04:03] |
Where can i find YOUR Symbol list for EUREX pack ? I mean , every data vendor has his dedicate symbol list , so which is your for EUREX pack. I cannot find it in your site. Thank you |
[2015-10-08 17:15:56] |
The symbols are different for every supported Data and Trading service Sierra Chart works with. You can find the symbols for the particular selected Service Sierra Chart is set to work with, through File >> Find Symbol. If that list is empty, then follow the instructions here: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
