Date/Time: Mon, 23 Dec 2024 16:37:49 +0000
replay do not work
View Count: 954
[2015-10-08 02:59:15] |
nicktrader - Posts: 717 |
I am running version 1303 and replay function do not work. Before updating I run 1297 and replay worked.
[2015-10-08 04:19:56] |
Review the documentation for this here: https://www.sierrachart.com/index.php?page=doc/doc_ReplayChart.html#BasicInstructions The issue is not specific to the particular version. Go through the instructions. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
