Date/Time: Sun, 04 Oct 2026 13:27:19 +0000
Select Font Family for the Custom Text Drawing Tool
View Count: 1181
[2015-10-07 15:50:34]
Stallwort - Posts: 3
I have a request for a change to allow choosing the font family for the custom text drawing tool. It would be very useful. I frequently use the Windings font for documenting things on the chart. As it is now, it is a manual process to change the font family manually each time I wish to use an alternative font.
Snapshot1 is an example of what I am requesting.
Snapshot2 is a simple example of using the Windings font (the 1 and 2 in a circle).
Thanks.
imagesnapshot1.png / V - Attached On 2015-10-07 15:48:30 UTC - Size: 35.14 KB - 416 views
imagesnapshot2.png / V - Attached On 2015-10-07 15:48:37 UTC - Size: 2.75 KB - 426 views
[2015-10-07 18:01:25]
We will see about this.
[2015-10-16 03:17:01]
Al SC Developer - Posts: 434
In the next version you will be able to set the font for each custom text drawing tool.
