Date/Time: Mon, 23 Dec 2024 15:30:52 +0000
Crosshair with Drawing Tool
View Count: 1228
[2015-10-07 14:50:32] |
MsJackson - Posts: 27 |
With a recent update, the crosshair now comes on any time I use a drawing tool. Can this be turned off?
[2015-10-07 17:22:14] |
Select Global Settings >> Tool Settings >> Chart Values. Set Always Enabled When Using Other Tools to None. We will solve this in the next release. It was mistakenly enabled. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
