Date/Time: Mon, 23 Dec 2024 15:04:11 +0000
BUY/SELL Entry formula
View Count: 866
[2015-10-07 02:45:29] |
User713273 - Posts: 409 |
=AND(V,X,Z,AB,AD,AE, TRUE, FALSE) Want to inlcude all exisitng columns in a buy/sell entry. What is needed to correct, seeing NAME? thx |
[2015-10-07 04:21:20] |
What is the problem with the formula? Specifically what cells are those letters referencing? Refer to: http://www.sierrachart.com/index.php?page=doc/doc_Spreadsheets.html#NAMEError Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-10-07 04:24:33] |
Got it thanks
