Date/Time: Mon, 23 Dec 2024 15:29:24 +0000
daily and pivot levels
View Count: 887
[2015-10-07 00:14:07] |
gmorgan111 - Posts: 121 |
I use the daily pivot levels on my chart. As I see them lines are drawn to connect the previous days levels to the current days levels. This makes the chart clutterd. Is there a way to just have the current days levels plotted and not the lines that connect the the current day to the previous day? Thanks |
[2015-10-07 01:15:57] |
Sawtooth - Posts: 4141 |
Set the Draw Style to Dash
[2015-10-07 19:01:51] |
Here is the documentation for Draw Styles: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#DrawStyle Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
