Date/Time: Mon, 23 Dec 2024 14:31:27 +0000
displayed value different color than line
View Count: 855
[2015-10-06 21:04:56] |
Seanz - Posts: 17 |
My current price line is colored Orange but its value displays in the 'values scale' as white. How do I make the value display in the same color?
[2015-10-08 02:28:56] |
You need to enable the Subgraph >> Value Label in the Study Settings window for this study. This is documented here: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#SubgraphsTab Although thinking about this, probably the last trade price box is drawn on top of the Value Label. So you have to change the color for the last trade price box. Refer to Graphics Settings for that: https://www.sierrachart.com/index.php?page=doc/doc_GraphicsSettings.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
