Date/Time: Mon, 23 Dec 2024 14:33:12 +0000
Pecentage change for all my charts don't update
View Count: 792
[2015-10-06 19:51:28] |
User795833 - Posts: 15 |
So each chart that I have on my screens don't update the percentage move. Stocks are down 4 percent, but it shows 0.22 or something strange. Is there some setting that is making it do this. Help. |
[2015-10-06 20:59:19] |
Are you referring to the Daily Net Change Percent field in Global Settings >> Customize Chart Header?
[2015-10-06 21:01:44] |
Yes.
[2015-10-07 03:31:01] |
This is calculated from the previous settlement price and current price as provided by Interactive Brokers. So if it is not accurate, there is not any help we can provide. Update: Try reconnecting to the data feed with File >>Disconnect and File >> Connect to Data Feed to get updated values. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-07 03:32:35
