Date/Time: Mon, 23 Dec 2024 15:21:29 +0000
Does "trade activity log" works with Lax ?
View Count: 919
[2015-10-06 17:08:25] |
sierra28 - Posts: 120 |
because no any trade statistics and all trades are "unmatched fill"
[2015-10-06 17:40:40] |
We do not know what is meant by "Lax" For an explanation of Unmatched Fills, refer to: https://www.sierrachart.com/index.php?page=doc/doc_TradeActivityLog.php#TradesTabUnmatchedFill Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-10-07 10:24:39] |
Sorry it is LMAX. After deleting all trades activity entry, same results: no trade stats and unmatches fill. (sim or non sim). Date Time Of Last Edit: 2015-10-07 10:25:10
trade activity log.JPG / V - Attached On 2015-10-07 10:25:03 UTC - Size: 112.68 KB - 300 views |
[2015-10-07 17:45:26] |
This is true with LMAX. This is documented here: LMAX Trading Service: How Current Trade Positions Are Determined All fills will always have an Open/Close of Open. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
