Date/Time: Tue, 08 Apr 2025 11:57:50 +0000
Deleting all drawings
View Count: 6418
[2015-10-06 11:53:07] |
User742670 - Posts: 43 |
Hi guys. simple question as I couldn't find it on site...how can I delete all drawings from one chart by one click except using the option hide drawings? Is that possible as I have so many lines in TPO chart which consumes lot of the math.processing of my CPU and its really painful to deleting each line separatelly. Many thanks Dave |
[2015-10-06 13:43:09] |
SC Developer - David - Posts: 662 |
You can select Tools >> Manage Chart Drawings Window then hold the Shift key on keyboard and select all drawings there then press Delete. The other way is to select Tools >> Erase All Text or Tools >> Erase All Non-Text Drawings to remove all text drawings or non-text drawings respectively. Refer to this section for more information: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ErasingChartDrawings Date Time Of Last Edit: 2015-10-06 13:45:06
[2020-12-13 12:09:02] |
Tofer - Posts: 38 |
Do not forget to check the "Multiple Selection" box when opening Manage Chart Drawings Window
[2023-09-26 21:06:49] |
User756079 - Posts: 9 |
Is there a way to remove all drawings, including the ones copied from another chart(s)? so what I want to achieve is by using one command/shortcut remove all drawings from all linked charts ? (couldn't find a way to do that) |
[2023-09-26 21:12:21] |
John - SC Support - Posts: 39199 |
There is not a way to do this. The only way to delete a copied drawing is by selecting it and deleting it individually. Selecting "Tools >> Delete All Non-Text Drawings" will not delete a copied drawing.
[2024-03-02 17:50:22] |
User763335 - Posts: 97 |
Hi Does the functionality to remove ALL chart drawings including Text, Non-Text and those copied from other charts exist or still not? Forcing the end-user to go to each and every chart to delete the drawings is not efficient. I should be able to delete ALL drawings on a given chart or all linked charts with a single click - a functionality provided in many charting platforms. can you pls include this functionality in near future pls? Will be a huge time saver. Thanks |
[2024-03-03 01:57:47] |
ForgivingComputers.com - Posts: 1040 |
Tools>>Manage Chart Drawings Window, then Check Select All, then Delete. You will have to do this on each chart. |
[2024-03-03 14:56:55] |
I dont think "Manage Chart Drawings Window" Select all , Delete, deletes chart drawings copied from other charts. Besides, going to each and every chart to delete all the drawings is not efficient. There should be option to 1) Delete all chart drawings on a given chart, including those copied from other charts 2) Delete all chart drawings across all charts of a particular ticker. |
[2024-03-04 15:19:14] |
There is not a global option to delete copied drawings. They have to be either deleted in the parent chart, or individually.
[2024-03-04 15:37:57] |
Understood, but can this functionality be added in near future? [ 1) Deleting drawings(including those copied from other charts) on a particular chart 2) Deleting all drawings across all linked charts of a particular ticker] Thanks |
[2024-03-04 17:23:09] |
We take all suggestions, but we can not say when we will get to anything in particular.
