Date/Time: Mon, 23 Dec 2024 15:17:16 +0000
Request for Formula Type 5 Pivots
View Count: 880
[2015-10-06 03:16:50] |
User544510 - Posts: 2 |
Request you add formula type 5 to my pivot point calculation (Camarilla Pivot Points.) Thank you. |
[2015-10-06 03:55:48] |
Formula Type 5 already exists. So we are not clear as to what you are asking.
[2015-10-06 03:57:38] |
Misunderstanding on my part, please disregard. Thanks anyway. |
