Date/Time: Sat, 23 Nov 2024 03:16:08 +0000
Thinking about SC but have some questions
View Count: 1452
[2013-06-17 18:03:32] |
User44323 - Posts: 26 |
I use Interactive Brokers and I understand there have been some issues with them. I am interested in trying SC anyway and see if I can make it work. I use several indicators which I see are included in your software namely VWAP with stdev bands and moving linear regression with stdev bands. Which packages would I need to hook up IB to SC and trade through SC for futures AND for Stocks/ETFs (I'm assuming you can trade any product through SC)? I don't think I need the historical data since IB populates their own (crappy) charts with historical data, correct? Therefore I'm thinking package 1 is sufficient? Thank you. |
[2013-06-17 18:29:20] |
Sierra Chart can chart and trade any symbol that Interactive Brokers provides. You will need Sierra Chart package 1 or 3 for what you want to do. Either will be fine. Let us know if you need more help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
