Date/Time: Mon, 23 Dec 2024 14:34:11 +0000
toolbar colors
View Count: 957
[2015-10-05 19:59:24]
Dennis B. - Posts: 272
Your new feature in ver.1303 to colorize the toolbar tabs is neat. However, when using this feature it activates the cross-hair function across all charts. Very annoying.
[2015-10-05 20:22:53]
This would mean that you have selected Tools >> Chart Values or pressed the corresponding ToolBar button.
And you also have the Global Cursor option enabled:
http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#GlobalCursor
Otherwise, this does not make sense. We do not see this kind of problem and we cannot see how it would even happen to begin with other than if the Chart Values tool is selected.
[2015-10-06 18:47:27]
All I can say is this, in prev. ver.1297 when I used a tool..horz.line vert. et. the cross-hair did not engage. Even though global cross-hair was on. In ver 1304 the cross hair comes on the chart no matter what tool I use. Even if it's off. But I'd rather deal with it than have you change code and possibly effect some other function. Oh, btw the colors on the toolbars are very pretty....LOL
[2015-10-06 19:20:42]
Set Global Settings >> Tool Settings >> Chart Values >> Always On When Using Other Tools to None.
[2015-10-06 19:41:54]
Yup, that did it....always hiding things from us. :-)
