Date/Time: Mon, 23 Dec 2024 12:56:57 +0000
Order target reset
View Count: 823
[2015-10-05 17:45:11] |
User170575 - Posts: 221 |
Hi, What did I do to cause my order targets in the chart trade window to reset back to the default(from price to back to ticks)? Is there a place to set a global default? Also, in some cases I was not able to drag the order to make adjustments? Thanks, Cy |
[2015-10-05 18:50:03] |
Maybe you changed the Trade Window Configuration: https://www.sierrachart.com/index.php?page=doc/doc_TradeWindow.html#TradeWindowConfigurations There is no global default for this. Here is the documentation to modify orders on the chart: https://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#ModifyingOrdersOnTheChart If you are still having trouble modifying an order, we need to have a better understanding of exactly what you are doing and exactly what is happening or not happening. Does the order line not move at all? That would indicate that Trade >> Chart Trade Mode On is not enabled. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-05 18:52:00
