Date/Time: Sat, 23 Nov 2024 03:43:08 +0000
Automated trading examples?
View Count: 1918
[2013-06-17 17:58:22] |
User45685 - Posts: 36 |
I was wondering if anybody had a fully functional example code for automated trading with Sierrachart laying around. It doesnt need to be anything fancy, even if it is as simple as a Moving average crossover with some basic takeprofit and risk management code implemented. What i want to do is look at it and start working on my own automated custom study but i have no idea where to begin. Help is appreciated :) |
[2013-06-17 22:50:17] |
nevermind: http://www.sierrachart.com/index.php?l=doc/doc_ACSIL_ExampleTradingSystems.html |
[2013-06-18 01:48:27] |
In the case of an ACSIL trading system, the link you gave in the prior post, is the relevant information you are looking for. In the case of using a Spreadsheet for automated trading, step-by-step instructions with an example can be found on this page: http://www.sierrachart.com/index.php?l=doc/doc_SystemsAlerts.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-06-18 01:48:55
