Date/Time: Mon, 28 Sep 2026 03:04:32 +0000
Triggered step trail stop
View Count: 2749
[2015-10-05 15:10:32]
User713273 - Posts: 409
Trying to incorporate % gains/stops utilizing option prices as your % barometer within a DOM. For instance I would want an intial 10% stop loss until option price trades to a 2.5% gain, when that happens stop would move to breakeven or 0%.
How would I configure that with a trade window, visual would be appreciated. thx
[2015-10-05 18:52:47]
would this be the correct inputs?
imageimage.png / V - Attached On 2015-10-05 18:52:18 UTC - Size: 255.37 KB - 547 views
[2015-10-18 20:24:15]
Here is the documentation for Attached Orders:
Attached Orders
Be sure to refer to the section about using the Move to Breakeven for Stop feature.
It does not make sense to use a Stop offset of 0% or a Step Amount of 10%. In general, stepping by a percentage seems very error-prone.
Also, we hope you really understand what it is you are doing because it seems like the trading method you are incorporating using options is error-prone and can be unreliable. Theoretically it may seem good, but as a practical matter, it is not simple.
[2015-10-19 21:27:40]
Yes thank you for your concern. Before moving forward w/ any intative we backtest for weeks/months. The most important thing to us is the rotation of symbols within a trading session. Looking forward to seeing the improvement by adding new functions to ACSIL to support trading a symbol different than the symbol of the chart.
