Date/Time: Wed, 30 Sep 2026 00:12:18 +0000
Trade Entries
View Count: 1156
| [2015-10-04 22:30:53] |
| User713273 - Posts: 409 |
I would like to avoid getting into trades once I get out of a trade by allowing new entries to occur when the price changes by X amount from my initial entry. For Example if I get a buy signal at price 40.20 to go Long and if it goes to 41 my signal to exit will occur which is good. However, I may get another signal immediately after to get back in. I would only want to get back if the price dropped by X cents. How do I go about doing this? |
| [2015-10-05 16:06:44] |
Any advice?
| [2015-10-05 17:45:03] |
If you are using the Spreadsheet System for Trading study the formula will need to use J49. This is documented here: https://www.sierrachart.com/index.php?page=doc/doc_SystemsAlerts.php#CellJ49 It is your responsibility to determine the actual formula to use. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-05 17:45:24
