Date/Time: Sat, 23 Nov 2024 03:54:01 +0000
disconnect data service
View Count: 1403
[2013-06-17 17:05:00] |
RPinCAR - Posts: 27 |
How can I disconnect my data service, DTN, without opening SC? And then open SC using your data feed. Ron |
[2013-06-17 17:15:31] |
You cannot. But when you start Sierra Chart you can quickly go to File >>Data/Trade Service Settings and change the Service to another service. Sierra Chart will not immediately connect to the data feed upon startup. It will be a few seconds later.
