Date/Time: Mon, 23 Dec 2024 15:06:50 +0000
Floating candle data
View Count: 1152
[2015-10-03 20:28:56] |
tellerbe - Posts: 109 |
My individual candle data(open, high, close etc...) is floating on my screen. I would like to put in the space just below the tool bar.How do I do that?
[2015-10-03 21:59:16] |
You will need to uncheck Global Settings >> Tool Settings >>Save CTV Position Window for Each Chart. You can then position it where you want and it will remain in that location. Did you want it displayed at all times? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-03 21:59:36
[2015-10-05 00:48:29] |
Yes, I would like it on all the time. The data is listed in two lines. I would like it all in one line. I did what you suggested and it doesn't seem to work.
[2015-10-05 02:46:58] |
It will be a minimum of two lines. Refer to this section here for instructions to adjust the font size for the Compact Tool Values Window: http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ToolValuesWindowFont And enable Global Settings >> Tool Settings >> Chart Values >>Keep Compact Tool Values Window Always Visible with Tool. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-10-05 17:29:15] |
I went to "changing font.. screen. Could not save because the screen disappeared when I checked OK In the 7th step. also I did something so now I cannot adjust the vertical height of my chart |
[2015-10-05 17:37:50] |
You will want to change the font for the "Compact Tool Values Window". We verified that the instructions are correct. So we have an understanding of what you are seeing in the chart, post an image of it by following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-10-05 18:13:49] |
I clicked on Edit.Screen Images, Upload chart. Nothing happened. I figured out the vertical problem. Don't worry about it.
[2015-10-05 20:09:57] |
http://www.sierrachart.com/image.php?l=1444075722109.png I think I finally figured it out. |
[2015-10-05 20:30:36] |
http://www.sierrachart.com/image.php?l=1444076898654.png This is what it should look like |
[2015-10-05 20:35:09] |
I thought I messed up, but I didn''t The data that is messing me up did not oome through on the copy. Can't figure what the heck is happening.
[2015-10-06 02:34:59] |
In those chart images are you referring to the line of text which is only partially visible at the bottom of the chart? Looks like that is another Chart Region which has a small height. Refer to the documentation here to adjust the height of the Chart Regions: http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#AdjustRegions You will need to make it bigger. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-06 02:35:38
[2015-10-06 19:30:49] |
http://www.sierrachart.com/image.php?l=1444159717629.png The data I am talking about is in the up[er left corner. I'll try again. |
[2015-10-06 19:53:13] |
http://www.sierrachart.com/image.php?l=1444161091298.png Let's see if this works. |
[2015-10-06 19:58:16] |
Yes!!! I copied the data that was showing on my screen. I had to leave off the last two digits of the numbers because of space. At least you can look at what I am seeing. If we can't get it into the space just below the tool bar, I would be satisfied just to remove in from the screen. It only shows up when I engage one of the tools.
[2015-10-06 20:01:42] |
http://www.sierrachart.com/image.php?l=1444161622673.png I think this will be the real thing |
[2015-10-06 20:02:35] |
Yes! I was not copying the overlay.
[2015-10-06 20:31:59] |
This is the Compact Tool Values Window. You can prevent it from displaying by unchecking Window >> Show Compact Tool Values Window. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
