Date/Time: Sun, 12 Jan 2025 09:25:43 +0000
button options
View Count: 1234
[2015-10-03 14:32:24] |
User20450 - Posts: 330 |
would love to see a button config like investor RT . be able to create custom buttons , like rth/eth hours , turn indicator on and off on screen , etc thanks |
[2015-10-05 18:36:08] |
These already exist. Refer to the documentation here: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSettingsMenu.html#CustomizeToolbar You can add a button for Chart >> Use Evening/Full Session Also refer to this section here: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#HidingShowingStudy Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-10-06 23:39:32] |
thanks for the session button , i made that now , what about the study button to hide a study ? im not understanding that link u posted , i want to create a button that has a vwap ( example ) and be able to hit button to turn it on and hit button to turn it off on the screen , can this be done ? thankls |
[2015-10-07 03:35:24] |
There is no button. We gave you documentation about how to hide and show a study using a quick method: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#HidingShowingStudy Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-10-07 12:28:10] |
i understand that might work for you but im putting in a request for a button like RT has , for future update please , thanks
[2015-10-07 17:43:25] |
This capability is not planned to be added.
[2015-10-07 18:49:53] |
That's ashame , I run a trade room with lots and lots of sierra users and that was one of the biggest topics So please keep it on the list Thanks |
[2017-02-14 03:09:57] |
i have found way to build buttons to turn on and off studies if anyone wants to know
2017-02-13_22-08.jpg / V - Attached On 2017-02-14 03:09:41 UTC - Size: 14.93 KB - 254 views Attachment Deleted. |
