Date/Time: Mon, 05 Oct 2026 18:57:08 +0000
chart templete
View Count: 1554
| [2015-10-03 14:25:42] |
| User20450 - Posts: 330 |
is there a way or can u guys make new update to save a single chart template its easier to have saved single chart templates as well as chart books to navigate in building new chart books thanks |
| [2015-10-03 22:03:50] |
This already exist by duplicating a chart. Refer to: https://www.sierrachart.com/index.php?page=doc/helpdetails20.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-10-04 01:31:29] |
yea i know that way but its not to efficient , as in ninjatrader , u open a new chart and pick symbol and then pick a saved template . just easier imho then duplicating if that charts not open then having to reload new data into it , thanks |
| [2015-10-04 05:11:39] |
There is an easier way and that is to use File >> Find Symbol >> Duplicate Active Chart. The documentation here has been updated to explain this: https://www.sierrachart.com/index.php?page=doc/helpdetails20.html#DuplicatingCharts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-03-10 13:49:42] |
i understand that but what do i do if i want to build a new chart without opening a old chartbook ? i like the analysis option but dosent include color or bar type , there has got to be better option here , i have 60 guys in my room and we cant even share a chart without making a separate chart temp and duplicating chart , its very time consuming fwiw
| [2016-03-10 17:17:03] |
If you want to share a chart, then do the following:Select Chart >> Graphics Settings and uncheck Use Global Graphics Settings Instead of These Settings. Set the color and other graphics settings. Here are instructions: Graphics Settings Select File >> New Chartbook. Go back to the prior Chartbook through the CB menu containing the chart you want to share. Use Chart >> Duplicate Chart to Chartbook and duplicate it to the new Chartbook you created. Go to the new Chartbook through the CB menu and select File >> Save. Enter the File Name you want to save it as and press the Save button. Share the Chartbook file as explained here: https://www.sierrachart.com/index.php?page=doc/doc_Chartbooks.html#CopyChartbook Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-24 07:27:26
| [2016-03-10 22:37:14] |
right i know how its done , but to have to have the chart open some where else is a pain on the fly , just not user friendly , let me know what u can do
