Date/Time: Mon, 23 Dec 2024 16:37:52 +0000
[User Discussion] - the name of the collection of studies and pass protection
View Count: 1558
[2015-10-03 10:37:19]
inverter - Posts: 42
how to make their common name of a set of studies his name?
There have one example where 3 study in one koloni..uglavnom,, I want to call you all together with my name and put the pass. Is it possible ? and how ? thanks
imagestudy colect.png / V - Attached On 2015-10-03 10:37:15 UTC - Size: 25.23 KB - 302 views
[2015-10-05 08:08:08]
Here is the documentation for Study Collections:
https://www.sierrachart.com/index.php?page=doc/doc_StudyCollections.html
Here is the documentation for password protecting studies:
https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#PasswordProtectingStudies
[2015-10-05 08:36:18]
it seems that I did not get the right answer.
I wish that the chart is not visible to the study and setup seen ... but to take my title collection of studies on the chart. Is it possible?
[2015-10-05 09:34:58]
We are not understanding the question.
It sounds like you are asking about Study Collections and we did link to the documentation for that.
[2015-10-05 09:43:26]
I wish that these data to chart is just my term studies ..
imagestudy colect.png / V - Attached On 2015-10-05 09:43:21 UTC - Size: 25.23 KB - 317 views
[2015-10-05 17:20:52]
[2015-10-06 10:32:21]
means ... I want you here in the chart do not write all of this data collection of the study, but I want you to call,, one name as it is written in the command analyst.
Is it possible ? or if you can add to the new version ... thanks
imagestudy collect if wont my short name.png / V - Attached On 2015-10-06 10:30:05 UTC - Size: 18.77 KB - 318 views
[2015-10-07 13:00:20]
Sawtooth - Posts: 4141
This is not directly supported. However, here is a workaround:
On the Settings and Inputs tab:
-Enter the study collection name in the Short Name field of one of the studies in the study collection.
-Enter a 'space' in the Short Name field of all other studies in the collection.
On the Subgraphs tab:
-Uncheck 'Display Name and Value in Region Data Line'.
-Uncheck 'Always Show Name and Value Labels When Enabled'.
[2015-10-08 08:53:42]
Settings and Inputs tab? chart setings or study setings?
Date Time Of Last Edit: 2015-10-08 08:54:08
[2015-10-08 12:38:26]
GO to Analysis >> Studies >> highlight the study >> Settings button
[2015-10-08 12:44:02]
about that, should each study separately from the setup ... I got a part,, it will be ok ..if not be otherwise ... thanks a lot.
[2015-10-08 12:46:39]
You'll need to do the steps in post# 8 for each study.
[2015-10-09 16:28:06]
OK, I got well. thanks a lot,
you understand well the spreadsheet. whether perhaps doing programming,, one of my ideas etc ..?
[2015-10-09 18:44:29]
Contact me here:
http://www.sawtoothtrade.com/contact.html
[2015-10-12 12:22:14]
ok..sent
