Date/Time: Mon, 23 Dec 2024 15:18:45 +0000
Chart Drawing Alert Not Saved to Tool Configuration
View Count: 799
[2015-10-03 09:44:59] |
User765038 - Posts: 22 |
SC Support, When assigning a specific tool configuration to a chart drawing, different alert sounds do not appear to be saved but always default to that previously used. Should it be possible to assign different alerts sounds to different tool configurations? Thanks and regards, Rod |
[2015-10-06 03:52:31] |
We have tested this and this works under the condition that you are applying a saved Drawing Tool Configuration to an existing drawing by following the instructions here: http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ApplyingPredefinedConfiguration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
