Date/Time: Sun, 08 Sep 2024 01:48:08 +0000
What is the lightest running version of Sierra Charts?
View Count: 800
[2015-10-03 08:19:46] |
User37129 - Posts: 15 |
Hi there, I am looking for the lightest running version of Sierra charts, that requires the least amount of RAM, and uses the least resources. Please advise, BF. |
[2015-10-03 09:23:55] |
You will want to use the version of Sierra Chart with New Spreadsheets which is our main release. Most likely that is what you are running. You can tell by looking at the top line of the Message Log opened with Window >> Show/Hide Message Log. The memory use and CPU usage depends upon what you are doing with Sierra Chart. That is what has control over these things. It is not the particular version of the software. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
