Date/Time: Wed, 01 May 2024 22:37:54 +0000
Using Code to Set a color Hue, Sat and Lum
View Count: 1010
[2015-10-02 23:18:30] |
KhaosTrader - Posts: 128 |
Hi, I understand how to use the RGB function to set a color, but is there a way to also set the Hue, Sat and Lum by code also? Thanks in advance |
[2015-10-03 00:49:39] |
No, this is not supported. Only Red Green Blue intensities.
[2020-02-21 09:01:15] |
Ackin - Posts: 1865 |
Sierra Chart Engineering) 5 years later .... EDIT: solved.... the code for it is done....Thank you for the answer Date Time Of Last Edit: 2020-02-21 17:05:17
[2020-02-21 09:57:04] |
How would that be done? Colors are specified as RGB values to the operating system. There simply is not any lagging behind here at all. This is a completely unnecessary request. The graphics library we use in the operating system does not support this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-21 09:57:36
[2020-02-21 16:29:49] |
bradh - Posts: 854 |
There are several examples of code that will perform this conversion if you search for it. |
[2020-02-21 18:04:56] |
Yes that there are certainly conversion functions available.
